TwinTurbo.NET: Nissan 300ZX forum - If an auto tranny (and tranny is attached) -- remove
jzack
on April 08, 2011 at 7:40 PM
How is the bolt tightened on the Auto tranny? (n/m)
posted by Havoc300 (Chicago)
on April 08, 2011 at 03:49 PM
the start motor and wedge a screwdriver in the flywheel teeth inside. Not all that hard to do just be sure the battery is fully disconnected before messing with the starter wires...
Crank Pulley bolt removal..
Havoc300 (Chicago)
14:05:12 04/07/11
Lefty loosie baby! (n/m)
BoneZ
14:08:48 04/07/11
Thanks! 3 days & I'm still trying. No impact wrench. (n/m)
Havoc300 (Chicago)
14:24:50 04/07/11
breaker bar? (n/m)
BoneZ
14:51:29 04/07/11
Use a long pipe or breaker bar..
KongZTT GT28RS MD
14:51:42 04/07/11
I thought I was the only one to try that (n/m)
ZiNnYc
17:50:28 04/07/11
we "GTFO'ers" think alike :) (n/m)
KongZTT GT28RS MD
19:13:44 04/07/11
hei. crank pulley bolt...GTFO (n/m)
ZiNnYc
21:45:54 04/07/11
I just removed mine last night. I spraying penetrating lube
Samuel (Dallas)
15:59:09 04/07/11
Hey Samuel... Check Email. (n/m)
Havoc300 (Chicago)
16:38:25 04/07/11
I would use a 1/2" drive ratchet on it..
KongZTT GT28RS MD
19:17:07 04/07/11
Fuel pump relay out of course! (n/m)
BoneZ
20:25:03 04/07/11
yep. or just disconnect PTU or CAS
KongZTT GT28RS MD
20:47:16 04/07/11
Yeah, wouldn't want to see the "I tried this and..." post (n/m)
BoneZ
21:51:01 04/07/11
Bumping the starter is the best method. Put a piece of
zellamay
21:03:21 04/07/11
Worked like a champ. Thanks Guys!! Now.....
Havoc300 (Chicago)
10:20:22 04/08/11
The key on the crank and pulley will keep it from turning. (n/m)
Woody75 (Denver)
11:48:30 04/08/11
Need to do this on my Automatic trans car. How to tighten? (n/m)
not4resaleZ
12:20:33 04/08/11
Should be able to do in park. (n/m)
KongZTT GT28RS MD
14:19:36 04/08/11
Use E-brake too (n/m)
KongZTT GT28RS MD
14:20:34 04/08/11
I always hate to load the trans in park. I may remove the
not4resaleZ
14:28:29 04/08/11
Guess there is also the "Belt Wrap" method. (n/m)
not4resaleZ
14:33:22 04/08/11
You aren't putting THAT much stress on the trans..
KongZTT GT28RS MD
15:07:19 04/08/11
Which I don't do. I use the parking brake for that.
not4resaleZ
16:30:03 04/08/11
put them on the ground :)..
KongZTT GT28RS MD
19:33:32 04/08/11
no...you'll just spin the torque converter (n/m)
aliaZ
06:48:50 04/10/11
Put car in 5th gear.. (n/m)
KongZTT GT28RS MD
14:19:21 04/08/11
oh yea.. and use E-brake. (n/m)
KongZTT GT28RS MD
14:20:12 04/08/11
Havoc300 (Chicago)
15:49:50 04/08/11
I just answered this above.. use your ebrake..
KongZTT GT28RS MD
16:29:21 04/08/11
Won't work, The torque converter slips. (n/m)
Fast300
22:54:34 04/08/11
If an auto tranny (and tranny is attached) -- remove -
jzack
19:40:16 04/08/11
Just use the e brake.. why go through all that? (n/m)
KongZTT GT28RS MD
19:48:46 04/08/11
Because it won't work the torque converter will still slip.
Fast300
22:50:23 04/08/11
I didn't even think of that.. I don't own an auto..
KongZTT GT28RS MD
13:34:23 04/09/11
